zelim000 Posted Wednesday at 12:01 AM Share Posted Wednesday at 12:01 AM Hey. Hope someone can help me. I have a e250 cdi 2009 and currently experiencing that when I hold the gas pedal flat on my car for about ten seconds it goes into limp mode and throws check engine. The code is P226300. Things that are done to eliminate the code are all the sealings are changed around the intake manifold. The vacuum solenoids are changed so I know it holds pressure well now. The DPF is emptied, but the cat is still in there. Still the car throws check engine ang goes into limp mode. If I turn the car off and on it goes out of the limp mode, but check engine is still there. If I again hold the accelerator for about ten seconds it goes into limp mode. Does anyone know what the issue might be. Quote Link to comment Share on other sites More sharing options...
