Oddih
S211.222; Feilmelding: "Intell. Light System virker ikke"
Posted (edited)
Hei, jeg får meldingen: "Intell- Light System virker ikke". Har en MB S211, E320 CDI.
Noen spørsmål ang. denne feilmelding:
  1. Hvilken styreenhet har feilet?
  2. Hvor er denne plassert?
  3. Kan den repareres?
Edited by Oddih
Share this post
Link to post
Det kan vere ein sensor eller lyktemotor. Du må starte med å få lest feilkodar. 95% sikkert så gir det deg svar.
  • Like 1
Share this post
Link to post
Takk skal du ha. Ja, jeg burde nok ha startet med det.
Er det noen som har tips om kit for å lese ut, og evt. nullstille koder på denne bilen?
Jeg har pleid å bruke verkstedet til alt, men tenkte nå å undersøke litt mer på forhånd selv. Er det eventuelt noen i Trondheimsområdet som kan lese ut koder?
Share this post
Link to post
Kjøpte en ICarsoft V2.0.
Her er utskrift:
BENZ_EN_TEST_00004>E(211)>As of 06-2006>T-Model>Diesel>211.222 - E 320 CDI>Manual>IC - Instrument Cluster>Read Fault Code:
Total Number : 6
9106 1/6
State: Historic
Fault in CAN communication with control module HRA Headlamp range adjustment
9128 2/6
State: Historic
The supply voltage of the control module is too low(undervoltage)
9129 3/6
State: Historic
The supply voltage of the control module is too high(overvoltage)
912D 4/6
State: Historic
The preglow lamp is faulty
913D 5/6
State: Historic
Control module EIS electronic ignition switch has detected undervoltage
913E 6/6
State: Historic
Control module EIS electronic ignition switch has detected overvoltage
Her er en til:
BENZ_EN_TEST_00004>E(211)>As of 06-2006>T-Model>Diesel>211.222 - E 320 CDI>Manual>XALWA_L - Xenon Headlamp, left>Read Fault Code:
Total Number : 10
9004 1/10
State: Historic
State of terminal 56b unreasonable
9005 2/10
State: Current
Communication fault with control module XALWA-R(Xenon headlamp, Right)
9040 3/10
State: Historic
No CAN data was received from control module AIRmatic or ENR
9060 4/10
State: Historic
No CAN data was received from control module ABR or ESP
9061 5/10
State: Historic
No CAN data was received from control module CDI or ME-SFI
9062 6/10
State: Historic
No CAN data was received from control module SCM [MRM]
9063 7/10
State: Historic
No CAN data was received from control module EZS(Electronic ignition switch)
9064 8/10
State: Historic
No CAN data was received from control module CGW(Central Gateway)
9068 9/10
State: Historic
906C 10/10
State: Historic
CAN timeout fault
Høyre Xenon lys er mørk, men denne gir egen feilmelding i displyet i bilen.
Share this post
Link to post
9005 2/10
State: Current
 det betyr at det ikkje er kommunikasjon med lykt, og ILS vil då sjølvsagt ikkje fungere.
kva som er årsak er vanskeleg å sei. Sjekk ledningar og koblingar.
dei andre feilkodane er historic, og er ikkje nødvendigvis gjeldande.
du kan slette alle, og lese ut på nytt, så ser du kva som kjem tilbake
Share this post
Link to post
Tusen takk skal du ha. Har jobbet med å få orden på feilkodene fra instrumentet siden sist (importert til Excel):
Ja, du har helt rett, må starte med å ta ut høyre lykt og rengjør koblingene og sjekke ledningene.
Share this post
Link to post
Posted (edited)
Sitter og studerer feilkodene, fant en til som kan være relatert til dette(?):
Edited by Oddih
Share this post
Link to post
Et lite tips mht feilkoder. Skal jeg finne en feil på en bil, henger jeg på diagnosen og tar en kikk på feilkoder. Så resetter jeg alt, tar en liten tur med bilen og leser av igjen. Da har man som regel det essensielle for å finne feilen. På første avlesning kommer all drit som er akkumulert, kanskje i åresvis, så det virker ofte mer forvirrende enn opplysende.
Når jeg hengte på star på bilen til junior, så jeg blant annet at forrige eier hadde ei lyspære som var gått på båthengeren hans :evil4:
  • Like 1
Share this post
Link to post
Posted (edited)
Den koden er og høgre framlykt. Om den skaper problem for ILS veit eg ikkje, men ikkje utenkeleg at det er ein samanheng.
Har du prøvd å skifte pære? Gåen pære vil gi den feilkoden.
Som sagt, sjekk tilkoblibgane til lykt. Det står ein styreenhet på lykta, reknar eg med, det kan og vere den som er defekt.
Edited by Simen Arntsen
  • Like 1
Share this post
Link to post
Takk skal du ha. Motortrade i Tr.heim kikket på den. De sa pæra var i orden.
Må vel av med støtfangeren for å ta ut lykta for å inspisere koblinger og ledninger.
Noen som har tips utover å inspisere koblinger og ledninger? Noen "lure" steder å sette på multimeteret?
Share this post
Link to post
Som sagt trur eg det er ein styreenhet på kvar lykt. Den handterer i tilfelle i alle falk ILS, men kan og vere involvert i styring av ballasten. Viss spenning og canbus til denne er i orden, kan det vere den som er problemet.
  • Like 1
Share this post
Link to post
om du trenger deler til ils lykter. så har eg det. mine tullla. men der var det min feil. sprengte styreenheten til lysa. men har ein kontroll enhet til lykta.
  • Like 1
Share this post
Link to post
